HELP NEEDED ASAP: Loud Pipes
#81
RE: HELP NEEDED ASAP: Loud Pipes
if u want loud...thunderheader is your answer....i had thunder on my 3 last bikes.....now i have Rinehart TD on my 07 ultra, its very loud too, who say Rinehart isnot loud..?? my Rinehart TD is very loud but at highway cruise not annoying loud like thunderheader....i can still hear my stereo at 70 mph clearly.....on thunder header i only can hear the stereo clearly at max 60 mph.....
i love Rinehart, very deep at idle, rumble, and will BARK like hell if we get on it...
#82
Hey bro... I trust you. Don't get me wrong. I told you that I would forward the responses of Jamie, which is what I did.
I just sent off that other question to Jamie: "Does the AFV reset between engine-running sessions or not?"
I will let you know when I hear back from him.
As for running a couple of tanks of gas, then switching, and then switching back again... trust me, I don't have the time to do that. Any by "time", I mean I won't have enough riding time left in this year... some snow on the ground this morning when I got up. Hopefully it will be decent this weekend, so I can get the bike out again...
#83
I have the Python slip-on with V&H true duals and modified the baffels on my 05 king. You can remove baffles but you will loose performance. I'm still not satisfied and like you want it abit louder. Thinking about the V&H Big shot duals???? I also have V&H Straight shots on my Low Rider and they do kick ***.That's why I'm leaning toward the Big Shots.
05King
06 FXDL
05King
06 FXDL
#84
Glens... I got a response to thatquestion you mentioned...
Here is my message to Fuelmoto:
Another question for you...
Also, received the PCIII in the mail this evening... will attempt to install
over the next day or so. Please get back to me regarding that question.
Cheers!
LARRY
Calgary, Alberta
And here is the reply that I received today...
The AFV does not reset between sessions, however it
has only a very small window of adjustment and this is
only in the area that is affected by closed loop.
Because of the small relative adaptive change the ECM
makes you do not need to reset the AFV. Our info is
based on the over 150+ 2007 bikes we have tested/tuned
in house and have sold a very high quantity of Power
Commanders.
Fuel Moto
Parts & Accessories
1020 American Dr. Suite #1
Neenah, WI 54956
Toll Free Sales 1-877-729-4754
Tech Support 920-729-4758
Specializing in EFI tuning and Exhaust components
Visit us at www.fuelmotousa.com
Interesting. I guessthat's theanswer you were expecting though, hey. Again... your thoughts?
Cheers!
LARRY
Calgary, Alberta
Commanders.
Fuel Moto
Parts & Accessories
Neenah, WI 54956
#85
#87
I replied already in the ECM-or-whatever forum.
https://www.hdforums.com/m_2412473/m...tm.htm#2413142
In just testing the link, I see I forgot to address the "only in closed-loop" bit they had to say. That's not true. The AFV works everywhere according to my sources of information. If it didn't what would be the point, and how would the necessary corrections be made in the open-loop areas of operation?
#88
ORIGINAL: LBussy
Here's something you may want to consider (but probably won't :P):
On a touring bike you are hopefully going to be doing some touring. Now I'm sure there will be people that tell you they have upswept fishtails directed in their faces on a touring bike and put on 800 miles a day ... good for them, but you get tired faster when you listen to loud pipes for a few hundred miles. I have either Wild Pigs (personal favorite) or SE muffs on my bike because it's a uniform thing with the drill team, but I'd personally prefer stock pipes for trips. I've tried ear plugs but those interfere with the communications so it's a definite disadvantage.
If you are dead set on loud pipes, may I recommend that you either get straight cut or slash-up tips? Slash-downs (and sometimes turnouts) reflect the sound back up at you and definitely work on your ears after a short amount of time.
In short, if you want to scream "look at me I'm so cool", at least be smart and put some thought into it.
#89
