ticking after warm up
Old 10-12-2007, 09:23 PM
bulldogmoe7's Avatar
bulldogmoe7
bulldogmoe7 is offline
Default ticking after warm up
i have amsoil in the engine. the level is fine. but after warming up it ticks. i just put the ids on about a month ago to get rid of the clatter, but now i hear the engine tick. it sounds like it is low on oil, but its not. could the amsoil breakdown and cause the oil to be really thin and not lubricate well enough? i dont believe this theory but i have to ask.
Old 10-13-2007, 04:06 AM
PapaTravis's Avatar
PapaTravis
PapaTravis is offline
Default RE: ticking after warm up
Well, I run Amsoil, and I have the same click noise. Sounds like lifters to me. I had the same noise before adding Amsoil, so I am not worrying about it. LOL
Old 10-13-2007, 06:56 AM
bulldogmoe7
ORIGINAL: PapaTravis
does yours getlouder after warm up?
Old 10-13-2007, 06:59 AM
Ultra_Bob's Avatar
Ultra_Bob
Ultra_Bob is offline
Injectors?
Old 10-13-2007, 07:09 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I have to agree with Papa.I went the same route and my engine sounds the same aswhen dino oil was used.
A lot of people swear syn. oil makes engines quiet,I dont agree.
Old 10-13-2007, 07:12 AM
choochoo's Avatar
choochoo
choochoo is offline
A basic tool every shadetree mechanic is a MECHANICS STETHOSCOPE!
Get one then use it! this will help you pinpoint where the noise is coming from!
It may becoming from the injectors which is normal.
But if it is coming from the lifters orthe rockers then no it is not normal.
If you find it is the lifters / rockers, drain the amsoil out and refill with a 20/50 dino oil or mobil one. run it again. If noise is gone fine. If not then it's tme for new lifters at a minimum.
Ultra_Bob's Avatar
Ultra_Bob
ORIGINAL: 1FLTRI4ME
My local parts counter stealer told me 'Syn 3' would make my engine quieter and 10* cooler ... I'm not so sure of that...
Old 10-13-2007, 07:23 AM
gunrunner's Avatar
gunrunner
gunrunner is offline
ORIGINAL: Ultra_Bob
ORIGINAL: 1FLTRI4ME
Might as well stick a 10 spot up his wazoo while your at it Syn 3 is the swill of pretend synthetic oils, its a low grade and not a true synthetic. Harley took the lowest offer from a oil company that would put it in their bottle. The harly dino oil is better than it is and half the price.
Old 10-13-2007, 07:48 AM
glens's Avatar
glens
glens is offline
ORIGINAL: bulldogmoe7
does yours get louder after warm up?
They all do, don't they? The multi-grade oil is an oil of the weight of the smaller number and is formulated to enable it to act as if it were the higher weight when at temperature.
I have, at nearly 9000 miles, much the same situation as initially described. I'm currently using Mobil1. It was the same with the "synthetic" oil the dealer put in at 1000 miles. It was also the same with whatever was in it when I picked it up at 9 miles.
It was the same with every motorcycle I've ever owned with whatever oil was in it at the time.
I can't say there's no problem with the original poster's setup because there's not enough specific information, but it doesn't "sound" like there's anything out of the ordinary to me.
Old 10-13-2007, 09:08 AM
electaRICK's Avatar
electaRICK
electaRICK is offline
simple,,,, its the "heart beat "of the beast
a sound to remind you theengine is alive!!!!
Quick Reply: ticking after warm up
