Satellite radio not as loud as regular radio
Old 10-12-2007, 02:01 PM
Ricks07's Avatar
Ricks07
Ricks07 is offline
Default Satellite radio not as loud as regular radio
I have a 07 Street Glide with the Hogtunes speakers in the fairing and the Hogtunes amp. Playing the radio or a CD and this set up really jams.
But....I just added a Sirius Starmate 3 which is sitting in my saddlebag until I get around to buying a handlebar mount for it. When I switch from radio or CD to Sirius, it is not nearly as loud. To the point that you cannot even hear it going above 60mph. When you turn the volume on the radio all the way up, it is just a distorted mess. But everything works great on the radio and CD.
The volume on the Starmate is tuned up all the way and the gain setting on the amp is up all the way. Has anyone else noticed problems with satellite not being as loud? Thanks in advance.
Old 10-12-2007, 02:08 PM
alexcue's Avatar
alexcue
alexcue is offline
Default RE: Satellite radio not as loud as regular radio
My XM coming from a Zumo 550 GPS does the same thing. And it doesn't matter if it's in a bike or car, there always seems to be a volume difference thru the aux input.
1potter1's Avatar
1potter1
1potter1 is offline
Yes,
mine's the same way with XM. I dont have a amp, I believe the AMP was suppose to be a remady for this problem. Earbuds does solve this problem and keeps the ringing out of your head after long rides.
Old 10-12-2007, 02:12 PM
Ricks07's Avatar
Ricks07
Ricks07 is offline
OK, cool. I have played with this thing forever trying to find out what the problem is. I thought the amp would help too but it doesn't. Thanks guys.
Old 10-12-2007, 02:58 PM
Jrsess's Avatar
Jrsess
Jrsess is offline
Thanks for the info,I was thinking of getting XM. Jrsess
Old 10-12-2007, 03:04 PM
cybdet's Avatar
cybdet
cybdet is offline
I have Sirius, No Amp and J&M Speakers and the Satellite radio sound much better than FM radio. I also have the Sirius wired directly to the AUX input rather than RF to an FM station.
Old 10-12-2007, 03:07 PM
billnourse's Avatar
billnourse
billnourse is offline
My XM is not quite as loud as the regular radio or CD player, but it is still good enough to hear at any speed I go. This is also true of the XM in my pickup and the wife's Sequoia.
Bill
Old 10-12-2007, 03:10 PM
kpb46's Avatar
kpb46
kpb46 is offline
My xm was the same way. But turning up the volume control on the xm Roady did the trick. Works great now
Old 10-12-2007, 03:15 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
On the RG I have a XM Sportscaster with built-in FM Mod... Mounted about 8" or so from the radio (above the ign switch) and running a hidden antenna in the fairing & it sounds GREAT... I seldom listen to the AM\FM or the CD... And have had very little loss or bleed from other Radio stations... (And living in So Cal you know there's a bunch of stations)...
Old 10-12-2007, 05:02 PM
greg09997's Avatar
greg09997
greg09997 is offline
There are 2 places to adjust volume with the Zumo 550. If you turn both up all the way you will see a big difference.
Quick Reply: Satellite radio not as loud as regular radio
