Latch on my saddle bags will not stay down
I have an 05 FLHRI Road King with the hard lockable saddle bags. I have one bag where the latch will not stay down. I can close the latch, but when riding down the road the latch will come up. I have had my bags off for cleaning and that is when the problem started. The latch does not look adjustable. Is there a specific way to put the saddle bags back on the bike. Is the latch adjustable.
RE: Latch on my saddle bags will not stay down
I checked my service manual for the 04 touring models and there are no adjustments on the latches. The only thing that i can think of is that your latch might be bent. They should not pop open while riding, but if you want to stop that from happening....just lock the latch when you close it and it should not pop open anymore. The bag can only be installed one way and there is not a way to install it crooked since the bar on the bottom sits in a groove on the bag and the two fasteners that hold it in, will only line up correctly in one place.
Good luck and examine it closely. You might find something lodged in the latch or on the lid keeping it from closing all the way.
Ride on.....
[IMG]local://upfiles/494/554B0BA72020486BBA6154D78FF54A62.jpg[/IMG]
Ride on.....
I have the same problem, but only when I have the bag full, locked or not it pop s open. After closing the lid I check it, try to pull up on it and it seems like it is locked solid. Then a couple hundred miles discover it is open again. Complained to the dealer and they didn't have and answer. Said as some of you posted, it's not adjustable. [:@][:@][:@]
Yo Charlie Z, FandangoZ, 06 Glide I'm gonna tell ya my brothers how to fix this and the reason I'm an expert on this is It happened to my 05 Road King when I first got it and it drove me effin crazy because it never happened to the mechanic when he test rode the bike, after I complained. I would go for a ride and the left bag latch would pop open, or up. The mechanic at my home dealer Liberty HD in New Jersey found the cause. Apparently the lid when closed creased the fabric on the condura piece that holds the top lid to the saddlebag so when you open and then close it it won't close tight enough to seal and lock. To fix it the fabric piece either has to be replaced or like the mechanic did for me a cheaper fix un bolt if from the lid and bag take it off turn it upside down and put it back together The only thing is that now the HARLEY DAVIDSON LOGO on the fabric piece is now upside down who cares you can't see it. Since that simple fix the lid or saddlebag hasn"t give me a problem since,works perfect! Ride Safe Brother, Bill NYC.
