Help with SERT, 08 RG
My 08 RG has Rush slipons (2 inch baffel) and a SE air filter. I just got a SERT and have been playing around with it. I actually have the bike running very good, nice idle, very good pull thru the gears, no popping on decell, and no ping. Plugs look great with a light tan.
I do have 2 questions I hope someone can help me with.
I started with a map off the CD and then tested and modified that map. I used map 100 because it was the closest to my bike and it worked well. There is another map, 101, which looks like the same as 100 but has HDI in the discription. What does HDI mean?
Second question. When starting to load another map into the ECU I get prompted with: ACR solenoid, disable or enable. I have read the manual several times and cant find anything on this. What is the ACR solenoid and should it be enabled or disabled. I have it disabled for now.
This SERT is a really neat tool once you play with it a while. I realize the best way is to put it on a dyno with someone that knows what they are doing. That just would not be any fun. I think I have it dialed in pretty good. Its alot faster (by the butt dyno) then my stage 1 06 EG so I must be doing something right.
Thanks for your time,
Doug
Doug
