Smart Security Help
Smart Security Help
I am installing the Smart Security System and Smart Siren II on my 2007 Road King Custom. The install seems easy enough - the siren came with detailed instructions; however, the Smart Security System did not really come with any install instructions (the sheet only made reference to the Service Manual (which is currently on order at my local shop) and the Electrical Diagnostic Manual). I have seen all the discussions and instructions about manually programming and marrying the TSSM (and the need to go to a dealer to have themmarry thefob using Digital Technician).As I am inpatient and would like to get this installed, I thought I would ask what I believe is my only remaining question: Where/How should I affix the security system antenna/cable? It obviously plugs into the TSSM via the supplied cable but I can't just leave it hangin' there - should I just cable-tie the thing anywhere that looks good? It almost lookslike it should clip somewhere but I can't see where. Any help would be appreciated.
Sorry for the dumb question & thanks in advance.
RE: Smart Security Help
Sorry, I guess I wasn't clear. I am OK with the siren install including the pager antenna....it's the TSSM and the associated antenna (part number 68956-07). The smart security system came with the following items: TSSM module, fob, cable, antenna module. I am just not sure where to secure that piece.
I ran into the same problem when I installed mine so I just used the supplied ties and attatched it to the wiring harness on the left side away from the battery. When I had the fob married I asked the service rep to make sure and he said that it was fine thereas long as it wasn't pinched or obstructed in any way. It's been there for over 5000 miles with no problems. The service rep said that it looks like it should clip somewhere but they haven't even been able to find where hence the wire ties.
Winners08Rocker
06-18-2012 09:41 PM
