HD Garage opener again....
Ok here is my first post on the subject.
https://www.hdforums.com/m_2282075/m...tm.htm#2282075
The door opens and closes perfectly with the switch of the hi/low...........until I plug the headlight in. Then it doesn't send a signal out at all.
Any suggestions?
I've also noticed that the bright light indicator is on all the time even when dim.......WTF!
Any suggestions?
RE: HD Garage opener again....
I double check that you're not getting a loose connection when you move the harness. I know when I put mine in that I found the connectors that HD provided to be pretty cheap. I just spliced the wires together and sealed with electrical tape. No problems with the opener at all.
ORIGINAL: sleepman54
ORIGINAL: screws4156
Ok I'm not trying to be mean, but if you don't knoe the difference between parrallel (More than one path for current to flow) and series (direct path, only one path for current to flow)Stop. Before you fry something.
