PCIII - 0 throttle fuel question
I'm not happy with how my bike is running with 0 numbers in the 0 throttle column. How many of you guys have played with adding fuel to that column?
My bike seems to just "shut down" when I let off on the throttle. Makes for a jerky ride when I'm on and off the throttle alot. Anyone know what I mean?
Thanks for any help guys.
Steve
Steve
RE: PCIII - 0 throttle fuel question
ORIGINAL: sifularson
Steve
Steve
I had the same problem and I contacted Dynojet and they had me change the values from 0 to 25 in the closed throttle position from 2000rpms
all they way down to 6500 rpms.
Also if you installed the power commander yourself they also told me I need ed to resetthe closed throttle position with the bike running and hooked up to the computer which the instructions tell you how to do.
I did both of those things and it eliminated the problem completely.
ORIGINAL: linck241
Steve
ORIGINAL: FLHT
Any of you guys with the 07s and running a PCIII having any pinging problems? My 06 is fine but my brother with his 07. Cracks the throttle hard and it will ping on him.
ORIGINAL: Uncle Peepers
I've run PC III's for quite awhile, and I always add fuel in the zero, 2%, and 5% throttle columns. I add it in increments of 1 or 2, usually as a means to tune out decel popping. Experiment a little; you'll get it where you want it.
Uncle Peepers
Uncle Peepers
ORIGINAL: gunrunner
Has he had the hd 903 donload? PC`III doesnt change timing on the canned maps, he might have to get it dynotuned.
ORIGINAL: FLHT
