PCIII help
Old 10-07-2007 | 07:57 PM
sifularson's Avatar
sifularson
Default PCIII help
Used a laptop today to set the throttle position. Before I set it, it was at 7% at no throttle. Reset it to 0.
Can't tell any difference in the way the bike runs. My question to the resident "PCIII Experts" in this forum is this:
1. What difference would it make to have 7% throttle at idle?
2. Anyone else have a similar experience with their PCs?
Thanks guys.
Steve
Old 10-07-2007 | 08:31 PM
jkoch09ultra's Avatar
jkoch09ultra
Default RE: PCIII help
When I had 5% at 0 throttle positon I had a very rough idle. Resetting the throttle positon corrected my idle. I think that a 5% to 7% at 0 throttle also will cool you bike in bumper to bumper traffic. I think that is what they do on the parade maps. I keep mine a 0.
I do have mine at 15% at the 1250 RPM and obove in the 0 throttle position. Takes the popping out when you are decelerating.
Old 10-07-2007 | 08:55 PM
sifularson's Avatar
sifularson
ORIGINAL: jkoch06ultra
I've noticed something since I installed the PC. I'll try to describe it the best I can. Maybe you and others can help.
When I let off on the throttle to slow down, the bike seems to abruptly slow down. It seems like the fuel is shut off completely and the bike slows down from compression. Kinda hard to describe. Maybe someone else knows what I mean. It didn't seem to do this as much when the bike was stock.
Maybe I should do what you did and give it more fuel at RPMs above idle at 0 throttle. It just occured to me when I read your post that this might be causing the issue I tried to describe.
Anyone????
Steve
Old 10-07-2007 | 09:00 PM
Taterdog's Avatar
Taterdog
You did the right thing by setting the TP to 0% and 100%. It's the only way the PCIII knows where it is in relation to your bike.
jeff194's Avatar
jeff194
My bike has done it since new, my 02 RK did not do this. Feels like a jake brake. I personally like it.
oldhippie's Avatar
oldhippie
I believe it is very important to set the 0% idle as I've heard it emphasized on here a few times.
I am "guessing" that the 0% throttle becomes the reference point for the rest of the throttle positions and hence if it's off, they'll all be off, but that's just a wild *** guess on my part.
Old 10-07-2007 | 09:11 PM
sifularson's Avatar
sifularson
ORIGINAL: jeff194
Yes, that's how it feels. The only reason I don't like it is that the bike is more jerky this way.
Old 10-07-2007 | 10:14 PM
skratch's Avatar
skratch
ORIGINAL: oldhippie
thats very accurate for a 'wild *** guess'.....
01RoadHog
05-04-2012 11:02 AM
mja52403
10-24-2009 09:37 PM
monsterglide2008
09-05-2009 08:32 AM
mja52403
10-24-2008 11:57 AM
Liketheglide
10-14-2007 08:37 PM
