What performance upgrades to buy?
Old 10-05-2007 | 04:58 PM
crzeigler's Avatar
crzeigler
Default What performance upgrades to buy?
I should be recieving my 08 RKC w/ABSthis month, what performance upgrades should I get. I've been hearing alot of talk about the heat which from all the talk is common. Any suggestions?
Old 10-05-2007 | 05:03 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Default RE: What performance upgrades to buy?
There's a bunch of threads on this issue...
Heat is a issue and EPA also.... Doing a Stage 1 will help address this HEAT PROBLEM & performance improvement... You may want to wait till the aftermarket has there Fuel Management Systems up and running... TMax with auto tune would be a Great way to go...
Old 10-05-2007 | 05:13 PM
glens's Avatar
glens
crzeigler:
Be careful. Going into a dealer and asking for a "stage 1" will not address heat issues since they'll load an EPA map into your ECU.
Evidently around here "stage 1" means some mufflers (or complete exhaust?), a freer-flowing airbox assembly, and some fuel management to get beyond the EPA limitations placed on the manufacturers, the dealers, and, technically, us. In the Harley shop, it will be HD/SE mufflers, HD/SE airbox assembly, HD/SE/EPA download (for fuel management). Which are both basically the same things, but not really. Depending on the shop/personnel, they may want to sell other-than-HD/SE parts but use the HD/SE ECU download. That is really not a good idea; at least it ain't the best one.
Also, around here, it seems, "pipes" are either mufflers or the complete exhaust system (the pipes leading to the mufflers).
Just a general heads-up.
Old 10-05-2007 | 05:15 PM
crzeigler's Avatar
crzeigler
Thanks glens
asahi1234
01-25-2011 07:02 PM
Chuck1
09-02-2007 09:12 AM
Nitehawk
Exhaust System Topics
08-09-2007 10:48 AM
budzilla
05-08-2007 01:35 AM
rock_drummer
03-25-2007 07:28 PM
Quick Reply: What performance upgrades to buy?
