internalwiring on 1" bars
RE: internalwiring on 1" bars
Hi, can't help you out with a link, but...
You'd prolly be better off buying pre-drilled bars as you really need an elongated slot at the base of the bars to make it easier to pull the wires thru, which would be difficult to cut. I put pre-drilled Flanders bars on my '97 softail. Beautiful chrome bars and reasonably priced. I believe they cost me $69 or $79, of course, that was back in '98.
[IMG]local://upfiles/4788/D4A69C10F6934BF9887AF2B558AD80E2.jpg[/IMG]
Internal wiring on 1 inch bars is a bit tight, you would be much better with 1 1/4 inch replacements. Here;s a link that may be helpfull https://www.hdforums.com/m_67666/tm.htm
I just ran the wires internally on my wide glide 1" bars last week. What I did was took the bars off and for the hole on the bottom I drilled 3 holes close together and cut them into 1 long hole with a cutting wheel on a dremel then rounded them alittle more with a carbide grinding bit. Same for the upper holes but I only drilled 2 holes there and connected them. The most important thing is to make sure you get all of the burres off or you WILL nick a wire. To fish the wires I first ran a piece of 12 ga solid copper wire through and taped the wires to it. It really wasn't as bad as I thought it would be. I'm sure it would have been easier with 1 1/4 bars but I bought my bike used and the guy I bought it from already changed the stock bars out for 1 " chrome bars so I really didn't see the need to buy new ones since I liked the look of what's there.
Do a google search for "internal handlebar wiring" you will get a lot of links with some good info.
Great information on this sight for wiring bars
I just have a (stupid) question........
I have 1" mini apes for my 2000 FXD... holes are drilled..
cables + brake line are bought..wiring is all set-when I put a wide glide frt end on
-had to-- cut ,solder,shrunk I will just redue
when I put the wires inside the bars do I leave them in the black sleeve ON
or remove the wires
I told you it was stupid but instead of finding out the hard way I'm asking
thanks
Mont
I ran the wires on my SG, 1" bars a couple of weeks ago. I did the bars just like "jv225" did his. It was a real pain in the butt, but I got'r done. I did leave the black rubber cover on the wires. The left side went pretty easy, but the right was tight. I had the cruise control added to the right side.
