Cruise, Brake Light... problem...
Old 10-04-2007 | 04:06 PM
Rocket Jockey's Avatar
Rocket Jockey
Default Cruise, Brake Light... problem...
OK, I changed handle bars on my RG and on my first ride a cager tellsme that my brake light wasn't working (it was actually always on). Then I noticed that my cruise would not stay engaged. I assumed I had cut a wire or two but they are fine. It is the little pressure button in the lever housing that is actived by the brake lever. When the lever is engaged, front brake applied, it releases the button and the brake lights come on. Obviously, that also disengages the cruise. I have had it apart, back together, pushed, twisted turned, etc. The lever doesn't fully depress the little button. I don't see any way to adjust it either. Any ideas??
Thanks,
RJ (Ruined my Junk)
Old 10-04-2007 | 04:34 PM
Jinks's Avatar
Jinks
Default RE: Cruise, Brake Light... problem...
Yeah, loosen the two screws that hold the master cylinder to the handlebar & move the whole thing back into the switch housing. Harley hasen't changed that switch in 20 years............
Old 10-04-2007 | 04:43 PM
scrubby64's Avatar
scrubby64
Had the same problem myself on my 2000 Roadglide, after much buggering around I pulled the brake lever out and put a large blob of JB weld on the "spud" which depresses the switch. No more problems.
Mark,
Belfast,
Norn Ireland.
Old 10-04-2007 | 04:45 PM
glide's Avatar
glide
If you didn't shim the lever when you reinstalled the housing, there's a good chance you broke the plunger that activates the switch.
Old 10-04-2007 | 04:48 PM
Rocket Jockey
I can't believe someone actually beatmy phriend UltraKla$$ic to the JB Weld solution!!!!
Jinks, tried that, pushed, pulled, no good.
RJ
Old 10-04-2007 | 04:53 PM
Jinks's Avatar
Jinks
ORIGINAL: Rocket Jockey
RJ
Did you take it apart & look at it? If adjusting the master cylinder/brake lever didn't fix it I suspect the switch in the housing is either loose or broken.
Old 10-04-2007 | 09:59 PM
buttman's Avatar
buttman
It's probably broken, the service manuel stresses shiming the switch for the front brake.
Old 10-04-2007 | 10:10 PM
Z_Stingray's Avatar
Z_Stingray
Insert a 1/16 inch shim on the back side of the switch. You can fold some black tape over about 6-8 times. Cut it to size and slide it behind the switch. This will push the switch towards the lever.
Old 10-05-2007 | 07:53 AM
NCCopBikeRider's Avatar
NCCopBikeRider
I knew JB weld would solve the problem
Old 10-05-2007 | 10:20 AM
Harleypingman's Avatar
Harleypingman
[Edit: May have gotten the switch operation "basackwards" as Glide said; will take a look later.]
It's possible the switch isn't broken; just shifted in the housing so the plunger which activates the switch is not fully opening. There is a brass clip inside the switch housing next to the plastic switch body that may have fallen out allowing the switch to shift inside the housing.
Hope you get it right.
Quick Reply: Cruise, Brake Light... problem...
