Cruise, Brake Light... problem...
RE: Cruise, Brake Light... problem...
Thanks guys. I didn't crack the manual for this, what I thought would be, simple straight forward job.......DOH. I did not shim the lever so I am sure I FUBAR'd the switch. The break light is working but the cruise won't stay engaged so I obviously still have an issue. I will tear it down this weekend.
When will I learn....
Thanks again for the help,
RJ
RJ
ORIGINAL: Harleypingman
RJ: How are you coming with the brake switch? For the brake light circuit to be open (and allow the cruise to work and turn off the brake light), the switch needs to be able to fully open which means the button under the rubber boot needs to fully extend out of the switch housing towards the lever.
JCBGlide
2014-2023 Touring Models
07-01-2018 04:21 PM
