Difference between J&M speakers (ohms)
Old 10-02-2007, 06:49 PM
tyrant33's Avatar
tyrant33
tyrant33 is offline
Default Difference between J&M speakers (ohms)
I am looking to buy some J&Mspeakers and I don't understand what the difference between these two speakers HCUS-06GT and HCUS-98GT. I am using the sony head unit that you see with the kit that comes on Ebay. I want to make sure I go with the correct speaker for this head unit. And could someone explain what the difference is between the 2 types of ohms for those speakers?
Do I need to go with a certain ohm for this head unit? or can I use either one?
Thanks
Old 10-02-2007, 06:53 PM
JMJOHN's Avatar
JMJOHN
JMJOHN is offline
Platinum Sponsor
Default RE: Difference between J&M speakers (ohms)
tyrant ,,,,,,,
the J&M #HCUS-06GT speakers are 2 ohms ,, the HCUS-98GT speakers are 8 ohms ,,,,,,,
what does the manual for the radio you are purchasing specify as the lowest impedance speaker you can use on their radio ? ,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old 10-02-2007, 07:01 PM
billydflnc's Avatar
billydflnc
billydflnc is offline
Which one is the better speaker... which is better higher or lower ohms??
Old 10-02-2007, 07:07 PM
tyrant33's Avatar
tyrant33
tyrant33 is offline
[*]I got this from there site[*][*]Frequency Response (Hz): 30 - 15,000[*]Stereo Separation @ 1kHz (dB): 35[*]Weight (lb/oz): 2lb 11oz[*]Depth (inch): 7-1/8[*]Width (inch): 7-1/8[*]Height (inch): 2[*]Preout Impedance (ohm): 220[*]Preout Max Voltage (V): 2[*]Power Ad Hoc (W): 23.2[*]Max Power Output (W): 52W x 4 (4 Ohms)[*]FM Usable Sensitivity (dBf): 9[*]Frequency Response (Hz): 10 - 20,000[*]Selectivity (400Hz): 75[*]S/N Ratio (dB): 120[*]FM S/N Ratio (dB): 67[*]Stereo Separation (dB): 85[*]THD (%): .5[*]AM Usable Sensitivity (uV): 30 [/ul]
Old 10-02-2007, 07:11 PM
sanaga's Avatar
sanaga
sanaga is offline
I THINK U BETTER STICK HCUS-06GT....
Old 10-02-2007, 08:12 PM
CSI's Avatar
CSI
CSI is offline
ORIGINAL: sanaga
What he said.
Old 10-02-2007, 08:52 PM
JMJOHN's Avatar
JMJOHN
JMJOHN is offline
Platinum Sponsor
tyrant33 ,,,,,
your radio specs say that it is capable of putting out a max power of 52w on each of 4 channels into a 4 ohm load ,,,,, which converted to RMS is maybe ABOUT 22-26 watts per channel continuous into 4 ohms ,,,,,
if the radio comes with a good warrantee, I would try the J&M HCUS-06GT speakers rated at 2 ohms,,, this will boost the output of the radio to 70+ max per channel into the 2 ohm load and if the final output amps will tolerate it, you will get the greatest volume potential from this combination ,,,,,,
if that bothers you, than go with the J&M HCUS-98GT’s at 8 ohms impedance ,,, and then you won’t need to worry about the final amps getting hot ,,,,,,
please let me know how you do ,,,,,
Old 10-02-2007, 09:02 PM
tyrant33's Avatar
tyrant33
tyrant33 is offline
So if I find a radio that goes down to a 2 ohms that would be better for the final amp? andI could use the 06gt's correct?
Old 10-02-2007, 09:14 PM
MyRide7's Avatar
MyRide7
MyRide7 is offline
[sm=deadhorse.gif][sm=headbang.gif]
Old 10-02-2007, 09:29 PM
CSI's Avatar
CSI
CSI is offline
ORIGINAL: MyRide7
Is it?
I remember speaker threads, but NOT one that asked about specific ohm requirements.
Quick Reply: Difference between J&M speakers (ohms)
