RG Front turn signals / marketing comments
[&:]In reference to my earlier post "Marketing Comments". The "U" trim on my 06 RG seperated from the fairing halves a while back. I loosened the 6-fairing screws and 4-acorn turn-signal screws to glue the trim back into place. Torqued all nuts back to spec.
My question; The HD shop manuel shows thateach turn-signal housing has two treaded studs with only one showing a lock nut. I'm a little concerned that when I loosened the turn-signal acorn nuts I may have lossened the studs too. Has anyone had the turn-signal housings off and seen if the threaded studs are simply loose screwed into the housing or part of the housing?
Nothing has fallen off yet, but there's still time.
