brighter Head lights
Just came home last night after a 600 mile ride, while motoring down the freeway I realized that I could hardly see the lines on the road. I have a 2004 EG with standard style head lights, what would be a good upgrade to get more light with out spending $700 for HID set up.
I replaced the 55/60 in the headlight with an 80/100 osram bulb. It's like driving in the daytime and no melt downs either. It projects the full beam from one side of the road to the other unlike the stock bulb that basically gives you a spot ahead of the bike and some light to the sides but not much. Just what I needed.
I installedtwo 50 watt running lights that I orderd from a local truck place ie Brake Drum and Spring, they sold me the flood lights and wala made all the difference in the world..I have the 4 1/2 spots on mine and the floods light up every thing you have to make a slight adjustment to the running lights but it is well worth the effort...
ORIGINAL: casique
Fastharley,
Are you running the HIDs yoou recommended? How are they and the installation? Thanks.
Fastharley,
As I said, see me for all warranty work or technical advice during installation. You can call me just about anytime unless I am sleeping, in the machine shop or riding (noise reasons only). I live in ft. Lauderdale, FL EST The buck stops at me.
A Couple of Suggestions
We upgraded the head light on our 06 Cop Gide to the Dual Halagon Bulb unit in the P & A Catalog.
We replaced the sealed beam Driving Lights with the Harley 68208-98A and upgraded the 27w bulb to an 886, which is 55w each
To add Depth of field and also to present a totally different picture to oncoming vehicles we added Motolights to the caliper with 55W yellow bulbs.
The total package brings a new dimension to riding at night.
We leave the Aux Lamps off during the day, and run with the Headlight and the yellow MotoLights.
Kinda Pricey for the total upgrade, but you can see at night and be seen during the day.
If you want to further enhance the light program, Daniel Stern will provide you with a head light reflector that will take two H 4 lights.
Still less $ than the Harley HID, but with as much light.
Good Luck
Good Luck
