Brake light, signal light flashers
Does anyone use any of the modules to flash their signal lights/brake lights when hitting the brakes? On previous bikes, including my 02 Dyna I installed a "Hot Shot" module from Kriss Electronics. It causes alternate flashing of the rear turn signals, and flashes the brake light. "Back Off" also has products like this. The biggest problem is the amount of wiring that needs to be done. With my soon to arrive new 08 Ultra I'm a bit more than hesitant to go after it with a wire cutter and soldering iron. I've also heard that some of them cause problems with cruise control and/or security systems. I would have thought by now that someone would have come out with a module that just plugs into the wiring harness rather than requiring cutting and splicing. Has anyone found anything?
Since a close call many years ago, getting rear-ended by a dope in a cage at a stop light has been one of my biggest concerns. The modules I've used in the past really work great to help "open the eyes" of someone behind you and get them to pay attention. Since the tour pack has additional lights I don't know if it will be necessary on the new Ultra, but if there was something I could just plug in I'd go for it in a heartbeat.
RE: Brake light, signal light flashers
I just did the back off module from signal dynamics. Its a pretty straight forward install. You do have to cut the harness though. I have a detachable tour pack with the spoiler led, and leds brake lights in my turn signal bar (not the turn signals)and I wanted to pick up all the lights on the module so I had to wire it in before all that. This meant cutting the hot wire for the brakes just out of the fuse block and splicingabout a foot of wire in so I could mount the module under the seat. I usedcrimp butt connectors with heat shrink tubing. Itworks great. You could probably get a plug in that would pick up someof the lights... do a search here for modulators...
DGlide04
10-05-2006 10:58 PM
