storage for winter
RE: storage for winter
I found a couple of web sites for you to look at, http://www.clarity.net/adam/winter-storage.html, and http://www.rmh-d.com/service/winterize.php. This should provide you with enough information. Obviously you don't have to follow these recommendations to the letter, just pick and choose what works for you.
For me the main thing is to change the fluids, top off the tank and add a stabilizer, put a battery tender on, and cover the bike. Where I live we do not have critters that would nest in the bike, but I know some plan for this and do things to their pipes (copper wool) and such. Hope this helps.
Here's what I do:
Fill up the tank with fresh fuel, add stabilizer. Ride it back home so the stabilizer made it through the fuel system.
Drain and replace all fluids. I use a decent dino oil for winter storage, and drain it off in the spring, replacing with my standard Mobil1 15-50.
Thoroughly wash and wax.
Pull plugs and fog the cylinders - reinstall plugs.
Hook up battery tender and cover.
Cry.[&o]
Cry.[&o]
To fog the cylinders just go to parts store and get a spray can of lightoil for this purpose. I'm not sure but I think the same company that makes "Stable" makes the product I use. After pulling the plugs you spray a small amount into each cylinder. Helps to keep cylinder walls from accumulating crap. My understanding is also helps to keep ridges from froming around the area where pistons sit's while stored. I also turnengine over, by hand,till piston is at top or botton of its stroke.
Change the oils
Wash&Wax
Put bike on a stand
Cover
Plug in battery tender
Leave it sit until spring, then ride
The one thing you want to avoid is starting the bike up in the garage over winter. The old myth that this charges the battery is just that, a myth. This will actually drain the battery and the engine will not get hot enough to burn off the condensation that will form inside the engine/tank/exhaust so that water will sit in those places and start eating things it shouldn't
Wash&Wax
Put bike on a stand
Cover
ORIGINAL: kong00us
only going to ride another month or so.Winter will be here...what do I need for storage this winter.have a RKC 2007.....battery tender,staibil for the gas,bike cover...will be in the garage...any suggestion?
thanks
thanks
Storage starthere in NH can vary from late Oct. - December. Last winter was warm!
