Cruise Control Installation
RE: Cruise Control Installation
I agree, easy install, BUT be sure to understand what you are doing when removing the ignition. Install took me about 2 hours. Making the ignition switch work properly again took another 2 hours. I did not pay enough attention to taking it apart and had to realign things before it would work properly again.
Ride Safe,
Mike
Ride Safe,
Mike
You have to take the ignition switch off to get the lower inner fairing off for the plug and wiring. In the directions it tells you to lock the forks when you take the switch out. The problem is, at least for me, when the forks are locked you can not get the lower fairing cap off. You can take the ignition switch out without locking the forks. You can also unlock the forks once the ignition switch is out. If you unlock the forks you will have to reset it back to where it was originally for it work properly. Just a little FYI for you. I have an 07 SG so I don't think there is much difference.
ORIGINAL: johnny5
Same as Streetglide2006, piece of cake to install, initialize; ignition switch was about a 2 hour time waster for me too. Works like a charm though!
Ride Safe,
Mike
