Cruise Control Installation
RE: Cruise Control Installation
Thanks for the tips on why I have strange things (no left and right turn signals, no front or rear brake lights, no cigarette lighter, etc.) happening after I installed cruise control. I DID check the fuse markedCRUISE/BRAKE and found that to be fine. I replaced it anyway............. no luck. I removed and reversed everything I've done for the install and................. no luck. I finally decided to re-install the cruise control and make an appointment with my local Harley dealership and let them find the problem at their painful hourly rate. In the process, I decided to check ALL 15a fuses and found the one marked BATTERY had failed! Because the bike started and ran fine, I never thought to check this fuse. I replaced it and now everything is right with the world!!!!! I have turn signals, brake lights, cigarette lighter, dash panel lights, cruise control indicator in the tachnometer face, horn, EVERYTHING!!!!! Now if I only can get the tiniest e-clip I ever seen installed I will try the cruise out!!!
Thanks for your helpful suggestions...................
