Cruise Control Installation
RE: Cruise Control Installation
Help!
I havea '07 ElectraGlide Standard (no security alarm) and I just installed cruise control(HD #77196-07) and now I don't have front and rear brake lights, left and right turn signals, and no cigarette lighter but I do have running lights, headlight, spot lamps, rear taillight, fender tip lights and the bike starts and runs fine.What should I look at first? The install went fine, not too tough. Any help will be appreciated.
And your right bllx, I already lost my C clip trying to install it.
Thanks guys ................
Now I'm curious. My cruise on my '94 stopped working this spring and parts are obsolete. In the manual there are many "deactivation" triggers to disengage the cruise lock. Front brake, rear brake, clutch, throttle roll back switch, speedometer reed switch and a couple of others that I can't remember. I had to check continuity in the harness and various swiches, etc. Long story short, I did something that fixed it.
I assume that the "add on" kit just plugs into the stock harness - was there a break down on the wiring schematic for the control module ? I might have to do a retro fit in the future.
Thanks.
Thanks.
My only prodlems and close calls:
Got inpatient and frustrated with ignition switch,watch that!
Lookclosely at connectors instead of cramming the wires in them(they pry open for ez placement of wires) couldhave been bad. also have to compare different pages in manuel for terminal #'s[:@]
Had no problem with loosing clip butdid not snap on all the way. almost sh%t when cc did not work at first,took almost an hour scratching my head til I saw cable just dangleing.
I installed a '93 model Cruise with the 94 harness in a 99 FLHPI. Simplified some of the circuitry by not installing the throttle roll off and such. It now has the brakelight light cutout and the on/off. I saved the schematics for it. If you would like, I can copy and send them to you along with the conversion pictures. It works great. I just had to fab a little piece for the end since It had the bolty-on end and the FI has the small clip over piece for it. As for running the wires under the tank... it's amazing what an old CB antenna piece with some duct tape will do when the tank is lifted from the back and still attached in the front.
That would be greatly appreciated my friend. With parts being put on the obsolete list yearly, I'm hosed for OEM cruise parts. Being able to do a retro with a newer part would be awesome.
Thanks.
Thanks.
ORIGINAL: roadtrash56
Most likely you popped a fuse. Most of the time when those lights are out your speedo will not work either. If this is the case....check the fuse panel under the left side cover in front of the saddlebag
ORIGINAL: oldhd
Help!
Help!
ORIGINAL: oldhd
Help!
Help!
