fuel pak
Old 09-26-2007 | 11:02 AM
jakedog's Avatar
jakedog
Default RE: fuel pak
Yep, it is a very simple install.....
Old 09-26-2007 | 11:23 AM
Bigbird07's Avatar
Bigbird07
well try thundermax efi controller no mapping, continually tunes as u ride, increase torque and horsepower, rev.limiter best of all it lower the temperature of your engine. all i can say it works very well for me and my 2007 custom road king..just do your home work of products before buying..check them all out. I'm not saying that vance hines pakisnot a good product. just giving you the scoop on thundermax www.thunder-max.com
Old 09-26-2007 | 11:39 AM
rome304's Avatar
rome304
one of the easiest mods i ever done.
[IMG]local://upfiles/22213/615C9D92464C40FEB458B492AC3B0C5C.jpg[/IMG]
Old 09-26-2007 | 12:09 PM
Lou70's Avatar
Lou70
If you want a simple, easy to install module, fuel pak is great! I have it installed on my RoadGlide. However, I just started looking into engine performance pieces and realized that most of them require an adjustable fuel module. So, I will have to buy another unit if I decided to build up my motor.
Old 09-26-2007 | 02:19 PM
Lost1's Avatar
Lost1
The Fuel Pak cools the engine pretty good, and I get 48-49 mpg at 60-65 on the highway.
Takes about 20 minutes to install & program and doesn't cost an arm & a leg...
Old 09-26-2007 | 04:42 PM
sofadog's Avatar
sofadog
Can you put on just the fuel pak and leave everything else stock?
Old 09-26-2007 | 05:37 PM
Lost1's Avatar
Lost1
ORIGINAL: sofadog
I run mine with the stock air cleaner and it runs fine. I have Rush mufflers with the quietest/smallest baffles (1.5") but I suspect it would run just fine even with the stock mufflers. They don't have a specific map listed for stock configurations but my WAG is that the map I'm using would work. Then again, a call to V&H tech support may reveal they have a map for stock rides & just don't have it listed on the web...
Bikz
11-01-2014 12:10 PM
32roadking
Touring Parts
09-24-2011 02:16 PM
WOLFE1584
10-15-2007 10:32 PM
Matrix
07-10-2007 04:31 PM
06glide
02-27-2006 05:14 PM
Quick Reply: fuel pak
