Gear Indicator-Dakota Digital
Anyone have one of these mounted on their bike.
http://www.dakotadigital.com/index.c...cat/cat298.htm
RE: Gear Indicator-Dakota Digital
No, but I had their speedo/tach/everything else console instrument on the Fatboy. Everything operated perfectly. The gear indicator operates by compairing the speed to the rpm. It's taught by a simple, one time setup you do the first time you use it. There is a second or two delay after a shift before the correct gear is displayed. No gear is displayed if you pull in the clutch.
David
David
BKSinAZ
09-26-2012 06:05 PM
aklim156581
06-09-2011 12:25 PM
dakota, davidson, davidsons, digital, gear, harley, harleys, hd, indicator, indicators, motorcycle, motorcycles, position, reviews, work
