Removing bluing on pipes?
Old 09-23-2007, 05:42 PM
Zack's Avatar
Zack
Zack is offline
Default Removing bluing on pipes?
What product is effect for removing the "blue" on pipes caused by excessive heat?
Old 09-23-2007, 05:48 PM
dirtdobber's Avatar
dirtdobber
dirtdobber is offline
Default RE: Removing bluing on pipes?
If it is a touring bike and the bluing is on the middle section as where there is no chrome heat shield just cover with a kuryakyn chrome heat shield or a hd one. That way you will not need to repeat the work. Blue away is what comes to my mind though.
Old 09-23-2007, 06:53 PM
stro1965's Avatar
stro1965
stro1965 is offline
I've had good luck with "Blue Job". Takes a while but it works for bluing and yellowing pipes.
Old 09-23-2007, 06:55 PM
GliderXXX's Avatar
GliderXXX
GliderXXX is offline
Blue Job works with a little...no check that...a lot of elbow grease.
Old 09-23-2007, 07:46 PM
spizzyman's Avatar
spizzyman
spizzyman is offline
Ihave not tried Blue Job. Nothing I have tried has worked worth a damn and Blue Away will scratch. looks like Blue Job will get the next attempt.
spiz
Old 09-23-2007, 07:59 PM
BIGCHIEF's Avatar
BIGCHIEF
BIGCHIEF is offline
I agree with the blue job recommendation. Just make it like toothpaste and rub for a little while. But you have to repeat it every couple of months. I think I'm going to go with the heat shield gap cover the others are talking about. I don't remember this happening on the 04 RK??
Old 09-23-2007, 08:08 PM
gene01's Avatar
gene01
gene01 is offline
Try barkeepers friend sold in the grocery store about 2 bucks a can...... it is a stainless steel cleaner it removes blueing fast and easy
Old 09-23-2007, 08:09 PM
DR.Greenthumb's Avatar
DR.Greenthumb
DR.Greenthumb is offline
Have any of you guys tried this stuff with steel wool? I think I read somwhere you could use #0000 steel wool on chrome with no scratches,wondering if that is fact or fiction.
Old 09-23-2007, 08:29 PM
daconiam's Avatar
daconiam
daconiam is offline
Try "Nevr-Dull", it will polish/clean any metal. Comes in a can of wool wadding or such....
Old 09-24-2007, 02:53 AM
PapaTravis's Avatar
PapaTravis
PapaTravis is offline
I use blue job. Sure, it does require a lot of elbow grease, but the results are great. One tip, when you get it up to the toothpaste phase (it is a powder and mixes with water), goop it on and let it sit for a bit. Not long enough for it to dry, but it seems to work better that way. What I do is smeer it on a small area, leave it for the length of a song on the garage radio, and just start rubbin'. LOL
Quick Reply: Removing bluing on pipes?
