Six Speed Trans
RE: Six Speed Trans
The IDS installed as standard on the 08, fixed the noises on the 07's that everyone is talking about.
I just took delivery of an 08 Street Glide and it runs like a dream and sounds good even without any changes to the pipes or stage 1.
Go ahead and take the plunge, you wont regret it!
RE: Six Speed Trans
The '08's were designed completely different than any other year in Honda Davidsonhistory.They threw away the mold after making the '08's. Every year pales in comparison to the '08's. They are more quiet and faster than the Goldwings. Honda Davidson took bits and pieces from the Knucklehead, Panhead, Shovelhead and came up with the D!ckhead for the new bikes............run out and get one. Maybe you and your friend should consider Metrics? Better yet, go buy a pre-07 bike, I hear they are worth THOUSANDS $$$$ more than even the new '08's MSRP......
Why don't you go ride one, then decide?
RE: Six Speed Trans
Two different problems with the 07s. Whine and Clatter.
HD installed a vibration damper in the rear sprocket for 08...namely the IDS. This IDS pretty much removed the "clatter" (metal banging noise) that some of the 07s had.
BUT... most of the08s I've heard still have the gear whine in 5th gear. Nothing to get upset about...
Get that 08 or get an 07 that someone is fed up with and install the IDS. It'll be a new bike after that.
IDS cost like 200 bucks...
Either way, you win. Great bikes.
lp
lp
ORIGINAL: elrod56
Thanks for the info guys,the one that said his was noisy was an 07 so i guess Harley has improved it for 08.
