Rider Backrest Install on StreetGlide
Old 09-20-2007 | 05:05 PM
soberglide's Avatar
soberglide
Default RE: Rider Backrest Install on StreetGlide
I have ridden thousands of miles with and with out that extra brace. I am 200lbs. and the two bolts seem to hold backrest secure enough for me. Of course I will assume no responsibility should it not work for you! lol.
51Moe's Avatar
51Moe
I did the same install too, didn't have a problem.
Old 09-20-2007 | 05:08 PM
StreetGlide2006's Avatar
StreetGlide2006
ORIGINAL: TRUBRIT
I think you need to re-check your install. I installed the same unit with brace on my SG with no problem.
Same here.
Ride Safe,
Mike
Old 09-20-2007 | 05:11 PM
bdavis's Avatar
bdavis
It is definitely installed in the right direction...just like the picture except it has a brace that is facing forward. The black brace they gave me is not long enough, and even if it was, it would have had to have been bent pretty severely to make the right angle.
Old 09-20-2007 | 05:21 PM
StreetGlide2006
The picture above is not the same as the mounting bracket I have. It looks just like it only on mine there is a piece welded to the front of the bracket that the black piece bolts to and then bolts to the battery box frame. If needed I can take a picture of it.
Ride Safe,
Mike
Old 09-20-2007 | 05:27 PM
duelly95's Avatar
duelly95
I have the forward brace on my Ultra, I wouldn't want to start tweaking the fender if I leaned back and put too much weight on it, Maybe you could ask the people you bought it from, maybe they have a longer black piece.
[IMG]local://upfiles/41721/83072B07F21746C595E7F187C08EF823.jpg[/IMG]
Old 09-20-2007 | 05:47 PM
bdavis's Avatar
bdavis
Mine is the same way. I don't think the problem is with the actual hardward the backrest slides into, but with the short black piece. I bought this off E-Bay but I'll see if I can get them to send me a longer brace. I guess I could just go to Lowe's. It looks like it would be easy enough to just get a longer piece of metal and drill some holes in it.
Thanks Everyone.
wascapsfan
02-12-2014 10:39 PM
WSRyda05
02-28-2012 10:57 AM
TurkeyRun
11-01-2011 07:12 PM
achog88
03-14-2008 01:25 PM
mhud
12-10-2007 08:02 PM
Quick Reply: Rider Backrest Install on StreetGlide
