belt deflection
09-18-2007, 08:14 PM
belt deflection
ive read in the manual about adj the belt (for after i do the IDS) but WHERE do you measure it? is there a guage or window down around the belt somewhere??
09-18-2007, 10:14 PM
RE: belt deflection
There is a window in the lower belt guard of the touring models that is marked off in 1/8" incraments. You should be able to see the belt or the cradle on the tension guage through the window.
Bill
09-19-2007, 04:38 AM
RE: belt deflection
thanks.
09-19-2007, 05:24 AM
RE: belt deflection
Set the belt with your riding weight on it, that way it will not be tight when it gets hot. Doc
09-19-2007, 06:13 AM
RE: belt deflection
How much torque on the pulley bolts? What else do you have to know? T
09-19-2007, 06:28 AM
RE: belt deflection
65 lbs with the supplied bolts that come with the IDS, It come with all the instructions but you can press the bearing in with out the HD tool. Doc
09-19-2007, 05:34 PM
RE: belt deflection
installed it today. thanks all.
Ozark Joe
EVO
07-15-2019 08:57 AM
hardheaded
08-17-2015 05:29 PM
OKIEVO
12-21-2007 12:10 PM
clayman
10-15-2006 03:08 PM
