Tank emblems
Old 09-18-2007, 07:57 AM
ianchris1's Avatar
ianchris1
ianchris1 is offline
Default Tank emblems
Anyone replace their tank emblem with a more retro look?
Old 09-18-2007, 08:36 AM
hdjoe88's Avatar
hdjoe88
hdjoe88 is offline
Default RE: Tank emblems
Yep. Part # 61776-61T. 1961 era.
Old 09-18-2007, 08:54 AM
ianchris1's Avatar
ianchris1
Was it a pretty clean install? Can you see anything left over from the original?
Old 09-18-2007, 09:17 AM
Punisher's Avatar
Punisher
Punisher is offline
I too am interested in the same thing. Is the emblem held on with 2 sided tape, and is the removal clean? Anyone have a picture to post?
Thanks very much
Woody
Old 09-18-2007, 10:45 AM
ckgdrums's Avatar
ckgdrums
ckgdrums is offline
ORIGINAL: Punisher
Thanks very much
Woody
Yes, double sided tape... used fishing line and cleaned up the sticky stuff with Goo Gone from Lowes.
[IMG]local://upfiles/18262/115BC0E660834A31B36E246EC2327A62.jpg[/IMG]
Old 09-18-2007, 11:16 AM
Punisher's Avatar
Punisher
Punisher is offline
Cool! Nice emblem by the way, I like it!
Old 09-18-2007, 11:22 AM
Motown_HOG's Avatar
Motown_HOG
Motown_HOG is offline
One of the first mods I did on the bike to make it different from all the other scoots out there. Easy to remove the old emblems and then used Goo-Gone to remove the sticky residue. The hard part was getting the new emblem brackets lined up properly by myself. Had to have the wife come out and keep telling me how it looked. Once I got them set I had to bend them to match the contour of the tank and then I was good to go.
I am actually thinking about changing mine again already to something else.
Old 09-18-2007, 12:12 PM
huffhuff's Avatar
huffhuff
huffhuff is offline
takes a lot of care getting emblems to look right and symetric from one side to the other. note that no many H-D emblems are parallel to the ground, most tilt to the rear slightly. it took me a long time to measure from several points to get mine to line up where they looked good. i see some that are "just stuck on" and look odd. enjoy!!
Old 09-18-2007, 12:27 PM
monsterdeluxe's Avatar
monsterdeluxe
monsterdeluxe is offline
I like the retro looking one. Having the 03 anniv I dont think I will make any changes. Even after seeing thousands of other ones. I like that it has three levels to it.
Old 09-18-2007, 12:36 PM
hdjoe88's Avatar
hdjoe88
hdjoe88 is offline
ORIGINAL: ianchris1
Getting the stock one off was pretty clean with floss, Goo Gone and WD-40. No scratches. I rode without any for awhile before deciding on the retro look. Installed myself. Decided where I wanted it, put one side on and then eyeballed the other side. I looked at a lot of stock emblems and how they were positioned. The emblem is held onto a bracket that has double sided tape by two screws.
Quick Reply: Tank emblems
