Batwing repair anyone?
Old 09-18-2007, 06:29 AM
grandpawmoses's Avatar
grandpawmoses
grandpawmoses is offline
Default Batwing repair anyone?
Well I've noticed a small crack on my batwing. It's at one of the windshield screws. The previous owner had replaced the stock windshield with a 6" deflector & probably overtightened the screw. Just knowing it's there bothers me so has anyone repaired or had a crack repaired? What's the recommended way?
Old 09-18-2007, 08:50 AM
Akitakoi's Avatar
Akitakoi
Akitakoi is offline
Default RE: Batwing repair anyone?
ABS Plastic, not easy to repair.
The crotch rocket guys.
http://www.sportrider.com/tech/146_0204_body/
Old 09-18-2007, 09:25 AM
TRUBRIT's Avatar
TRUBRIT
TRUBRIT is offline
ABS plastic, same as car bumpers. There are special glues for this. Check with any Auto Body shop or Auto supply shop and they will be able to help you.
Google : ABS plastic repair and you will get info on what you need to do.
Old 09-18-2007, 10:38 AM
krf48309's Avatar
krf48309
krf48309 is offline
Put a chrome accent strip over it.
Old 09-18-2007, 10:50 AM
Detro996's Avatar
Detro996
Detro996 is offline
3M has some products that work very well. I've fixed 2 inche holes on sportbike side panels. You can even make tabs where they have been broken off. Like someone said go to an autobody supply shop. You will be looking for 3M bumper repair, but you will want Rigid versus Flexible.
Old 05-09-2011, 08:49 AM
Pop Yearwood's Avatar
Pop Yearwood
Pop Yearwood is offline
6th Gear
The brass "nut" has come out of the plastic that the windshield bolt screws in on the fairing. . Anyone know of a product to adhere the brass fitting back to the ABS plastic?
Old 05-09-2011, 08:56 AM
viperr817's Avatar
viperr817
viperr817 is offline
Epoxy for plastic at autozone, then run a tap thru the threads to clear out any leftover cured epoxy in the threads. You can find the stuff at autozone, or Harley makes a repair kit.
Old 05-09-2011, 09:17 AM
Pop Yearwood
6th Gear
Default thanks
Thank you for your quick reply. Off to Autozone...will repost the results. Thanks again. Pop.
Old 05-09-2011, 09:35 AM
FDHOG's Avatar
FDHOG
FDHOG is offline
3M 5895 part A&B epoxy and 05907 Adhesion Promoting Spray
I use it to repair Pelican Boxes and other ABS pieces.
Pretty good stuff.
Old 05-09-2011, 09:36 AM
tx-skydiver's Avatar
tx-skydiver
tx-skydiver is offline
This may help. It looks like a batwing with the exact issue you describe is being repaired at 5:30 into video.
http://www.youtube.com/watch?v=IHKThXLk6Go
Quick Reply: Batwing repair anyone?
