Fork Locking Mechanism Problem??
Old 09-17-2007 | 09:46 PM
SparkyRKM's Avatar
SparkyRKM
Default Fork Locking Mechanism Problem??
Had my 2002 Ultra to the stealer for state inspection last week. While there, I had themcheck/adjustthe front fork bearings.I had the bike outyesterday for the first time since then and when I tried to lock it,discovered thefork lockdoesn't work. I thought maybe the dealerdidn't reassemble the ignition switch correctly. I disassembled and reassembled this switch but it didn't fix the problem. I checked all my manuals and can't find where theyillustrate the actual locking mechanism. Can anyone suggest where I should look next.
Old 09-17-2007 | 10:08 PM
Taterdog's Avatar
Taterdog
Default RE: Fork Locking Mechanism Problem??
I've got a 2000 Classic. My lock's been acting up lately so I was in my manual the othernight and found instructions how to remove/reinstall in the section about removing the inner fairing. Don't know where it might be in your 2002 manual, but you might check the fairing instructions.
Old 09-17-2007 | 10:11 PM
Garemlin's Avatar
Garemlin
Check your cable to make sureit isnot blocking the lock from engaging.
Old 09-17-2007 | 10:28 PM
rjw54's Avatar
rjw54
Check to see that there isn't anything between your fork bumpers, I had that problem with my RK.
Old 09-17-2007 | 11:30 PM
im's Avatar
im
as rjw54 stated i had a bit of difficulty and it was those rubber donut bumpers on the upper tubes that did not allow the bike to turn fully for locking on a road king classic...
Old 09-18-2007 | 05:03 AM
Warden's Avatar
Warden
I had the same problem when I disassembled the ignition. I made the mistake of turning the wheel to the left and it locked without the ignition in it. I spent 45 min trying to get it lined back up and then had the idea to remove the two screws that hold the entire ignition unit to the farring. It released the front end and reset the steering and ignition to center. I then re inserted the ignition and worked fine.
I hope all this makes sense.
hdwd2000
04-27-2016 04:37 PM
Papa G
05-19-2015 08:58 PM
langwilliams
05-19-2015 05:36 AM
rivercityslim
EVO
06-27-2009 04:41 PM
MdTIGwelder
01-02-2008 09:23 PM
