08 Street Glide Questions
I just got an 08 StreetGlide and have two questions......
[ol][*]Are the wires from the switch housings on the handlebars run in the handle bars or on the outside. I ask because mine are run on the outside and zip tied to hold them against the bars. My other bike is a Fatboy that the wires are run externally as well but instead of the zip ties there are a few holes in the bars with a black connectors to hold the wires looks much better than black zip ties on the new bike. I had quite a bit of work done before I got the bike and wonder if this was the dealers way of saving some install time instead of running the wires inside the bars. I also just noticed there are no holes for the black wire holders like the Fatboy. HMMMMMMMM???[*]I was told that the new bikes have a accessory plug that hangs from the area by the sidecovers. Is this true or not. I quess it would allow you to plug in an accessory or or heated items. Where exactly is it if this is true?????
[/ol]
[/ol]
RE: 08 Street Glide Questions
IT IS THERE. EITHER UNDER THE SEAT TUCKED OUT OF THE WAY NEAR THE BATTERY ON ONE SIDE OR UNDER THE RIGHT SIDE COVER. THE WIRES GO ON THE OUTSIDE OF YOUR BARS AND THE DEALER TOLD YOU RIGHT. HD OFFERS THE PLUGS ON THEIR ELECTRICAL WIRING THAT PLUG INTO THE ACCESSORY SOCKET WITHOUT ANY NEED FOR SPLICING. YOU CAN ALSO PURCHASE NUMEROUS FITTINGS TO EASILY MAKE THIS SOCKET ACCOMODATE 4OR 6 DIFFERENT ACCESSORIES CONTROLLED BY YOUR ACCESSORY SWITCH SO IF YOU ONLY WANT THE LIGHTS OR WHATEVER ON AT NIGHT.
ORIGINAL: HarlyFan
[ol][*]Are the wires from the switch housings on the handlebars run in the handle bars or on the outside. I ask because mine are run on the outside and zip tied to hold them against the bars. My other bike is a Fatboy that the wires are run externally as well but instead of the zip ties there are a few holes in the bars with a black connectors to hold the wires looks much better than black zip ties on the new bike. I had quite a bit of work done before I got the bike and wonder if this was the dealers way of saving some install time instead of running the wires inside the bars. I also just noticed there are no holes for the black wire holders like the Fatboy. HMMMMMMMM???[*]I was told that the new bikes have a accessory plug that hangs from the area by the sidecovers. Is this true or not. I quess it would allow you to plug in an accessory or or heated items. Where exactly is it if this is true????? [/ol]
ORIGINAL: HarlyFan
Where did you find the Stainless Steel ties???
jamminjimmi
08-28-2011 11:14 AM
