Lube Clutch Cable?
Old 09-15-2007, 09:35 AM
NICK56's Avatar
NICK56
NICK56 is offline
Default RE: Lube Clutch Cable?
lube em!
Old 09-15-2007, 09:40 AM
Bulldawg's Avatar
Bulldawg
Bulldawg is offline
Check out this link for Todd's Harley Tips and scroll down until you find the tip on clutch cable lubrication. Never tried it so don't know if it works or not.
http://moneycentral.communities.msn....ypix/tow1.msnw
Old 09-15-2007, 10:30 AM
brewdog's Avatar
brewdog
brewdog is offline
I'm surprised that HDdoesn't usepermantly sealed and lubed cables. I've never seen one come to think of it, but the the Auto companies use cables systems for transmissions and throttles and I don't see them going in every year for re-lube.
Old 09-15-2007, 10:41 AM
tlb's Avatar
tlb
tlb is offline
I use a needle and syringe to inject 3 in 1 oil down the tube the work the cable. mostly because my can of silicon spray does not have a nozzle tip for the tube. I think what i am trying to say is if you buy a cable luber make sure you buy a can of spray, other than WD40 that uses the small plastic straw to fit in the luber.
by the way WD40 drys up where 3 in 1 or silicon lubricant will not. just my opinion for what its worth.
Old 09-16-2007, 09:01 AM
BrianDamage's Avatar
BrianDamage
BrianDamage is offline
I bought a cable luber tool, but didn't use it...the dri lube I got at the dealer came with a syringe tip that was easy to use.
randazlr
06-26-2017 01:08 PM
dwoodlives
04-08-2017 08:18 AM
falconbrother
EVO
22
12-20-2015 04:41 AM
oinker02
05-30-2013 05:51 AM
ghoticov
07-29-2012 09:31 PM
Quick Reply: Lube Clutch Cable?
