can you run 100 octane LEADED GAS in the 2006 bikes? i have read post were people have used 100 octane gas. but i didn't know if they were using that high of octane on leaded or unleaded. or has any one ever tried this,,,thanks for your input,,,,,
It will run on race gas, but why would you want to? It costs over 6.00 a gallon and unless you have some out of the world compression its not going to do much of anything premium 93 won't do.
My '06 Ultra had one catylitic muffler (right one) as a stock set up. As I recall from the early 80's, leaded gas will mess up a cat muffler. You might want to check out your muffler configuration before using much leaded gas.
TNBagger is right if you have a Cat it will destroy it. I used to put cat eliminators for riding south of the boarder. I would just stay with the 93 octane like gunrunner said you just wont get anything out of it on stock engine.
You don't need any higher octane than what is recommended unless you have changed the pistons/cams/cylinders to be higher compression than stock. It will not make the bike run better, it won;t get you more power, it will only make you poorer and the gas company richer
