went air up rear shocks tonight and
RE: went air up rear shocks tonight and
My understanding is that oilmay sometimeswork its way up the air lines to the valve. If you want to let air out of the shocks you should connect the pump and ADD a bit of air first and then let the air out. Adding air pushesany oil in the lines backdown into the shocks so that it doesn't come out of the valve when you let air out.
There's one I will remember. Thanks for the tip Tech2
ORIGINAL: Tech2
