Pick up a service manual... you may need to get a Torx etc.. forgot what size it is and it's raining here or I would run out and check for you. Getting it lined up and the tabs in place going back on is the worst of it.
Remove the headlight assembly before re-installing the outer fairing. Then you will be able to see when the fairing is on the support hooks! Then just stick the 3 headlight adjusting screws back in place and snap them in.
I removed the turn signals and the 6 torx screws and there seems to be something still hangin on.
It seems to be behind or around the h/lights. Yall have any other suggestions?
