How Much to Install IDS?
RE: How Much to Install IDS?
I put mine on in 1 hour and 15 min. and that was taking my time. got it from zanotti with the bearing pressed in. it is a walk in the park. just get a torque wrench a 36 MM socket and if you got the tool kit with your bike, it has a 36 MM wrench to hold the welded side of the axle. And it is an upgrade that is well worth the cash it cost.
Ask a Dealer to quote you time to R&R Rear Drive Sprocket, and add 1/2 hour tops to install the bearing (if needed), check/clean threads, and lube/install the rubber bushings.
I did mine in 1 1/2 hours, and that was including refreshments and taking my time!
[sm=icon_cheers.gif]
Do the instructions come with the part, or in a manual? I have a bud that said he could help me if he has instructions. Because he rides a Texas Chopper he's not even heard of the IDS or even the noise problem with the '07 Harleys. I'm sure he will figure it out because he does all of his own wrenching.
Thanks,
Joe
Thanks,
Joe
