Cruise control problem 06 RK
Old 09-10-2007 | 07:06 PM
cwfore's Avatar
cwfore
Default Cruise control problem 06 RK
My 06 RK cruise is not always cutting off when the brake is applied. Doesn't matter if its the hand brake or the foot brake, I have to cut it off by the on/off switch. Also at times the cruise will start to increase speed and when it gets about 3 or 4 miles per hour over the set speed it will suddenely decrease the speed as if you cut it off back to the set speed. Does anyone have an idea or know how to trouble shot the cruise.[8D]
Old 09-10-2007 | 08:25 PM
Rick 547's Avatar
Rick 547
Default RE: Cruise control problem 06 RK
Reset the backlash. You will need a manual and follow the instuctions.
Old 09-11-2007 | 07:05 PM
cwfore's Avatar
cwfore
Thanks Rick
I've got a few days off comming up and will give it a try. Thanks for the info.
Old 09-13-2007 | 07:04 PM
Rick 547's Avatar
Rick 547
Ia your problem fixed?
johnod
EVO
07-27-2017 01:47 PM
erniek70
10-17-2016 08:59 PM
Larry Nawara
09-14-2013 05:05 AM
Road Hawg
06-12-2011 06:11 PM
DigitalSilver
03-27-2010 11:28 AM
Quick Reply: Cruise control problem 06 RK
