Could Use Some Input...
Old 09-11-2007, 11:46 AM
petemac's Avatar
petemac
petemac is offline
Default RE: Could Use Some Input...
If if were the valve seals, I'd think he'd have been having an oil consumption problem.
ORIGINAL: meyergsr
Take a look at the sparkplugs. I think some of the 05 TC had problems with faulty valve seals. This would cause poor running.
Old 09-11-2007, 12:35 PM
Cohiba_Joe's Avatar
Cohiba_Joe
Cohiba_Joe is offline
Thanks much for all the replies....I greatly appreciate it.
I was having thoughts in regards to the way the guy was quick to jump on the bandwagon for the whole "it's time to start looking at the engine" deal. I've got 30+ years under my belt in the auto service industry so I'm quite familiar with the workings of a combustion engine but I wasn't sure if a bike was really all that much harder on it's engine & drivetrain. I have already changed out the plugs & wires for the sake of the "process of elimination" and check them regularly; they always look good in regards to the burn pattern and coloring. Also the bike doesn't smoke and I have no problems with oil consumption.I will run a wet & dry compression test this weekend; other than making sure the cyclinders are within a proper balance with each other (i.e. comparable numbers) around what range should I be looking for in regards to the compression numbers? I'll also look into the cam chain tensioners and do a cylinder leak-down test if possible
In regards to the mounts; I've checked the front lower rubbermount and it has not separated but it might be getting to the point of being worn and allowing too much engine movement. In regards to replacing the mount has anyone had any experience with the Velva-Ride mounts or would the updated stock mount be suffice? Should I also consider replacing the twoengine stabilizersas well; do they go bad? Also, would the engine being out of alignment have any affect on anything other than the way the bike would track?
Thanks again,
Brian
WoodButcher66
2014-2023 Touring Models
27
11-01-2021 08:23 AM
Pouike
03-27-2019 10:53 AM
09883custom
05-29-2018 02:47 PM
RickV
Wheels/Tires
07-10-2011 02:47 PM
TexasBikeBoy
11-11-2009 06:16 PM
Quick Reply: Could Use Some Input...
