oil drip from primary
New to forum hello to all. Have a 2005 rode king that has a slight drip coming from the bottom of primary, I thought it may have been the drain plug so I replaced the o ring and changed the lube, still have that agravating little drip. Any sugestions other than changing the primary gasket. All help would be appreciated it just turned over 5500 miles.
RE: oil drip from primary
I just went through this and it was a worn shifter shaft seal. I'm told it is very common. If your drip is near the primary drain plug and drips down the jiffy stand, well it sounds like the shifter shaft seal. You won't be able to see it from the top, but if you can look under the bike between the primary and trans, you can see a little drip from the shaft. I borrowedmy daughters mirror and a strong flashlight to find the leak. My daughter is still mad.
If it is your shifter shaft, it is about $300 fix. If you don't mind little puddles in your garage, it is not critical to fix immediately.
Beary
Beary
Had a similar problem with my '06 Ultra awhile back and come to find out that it was caused by a warped inspection plate. The dealer informed me that if you take the stock plate off and replace with an aftermarket plate (the Harley Flames plate is also considered aftermarket) they have a tendency to warp.
DITTO here on an '05 Ultra with 15,000 miles - the exact same slow oil drip that appears at the primary drain but is NOT from the plug/gasket.
I get about 3 drops of primary oil overnight.
My 03 fxd developes similar leak. It leaves a couple drops on the floor after a ride and the drip comes from the primary drain plug area. I assumed it was shifter shaft seal. Used it as an opportunity to put on a chrome inner primary with new seals and bearings. Guess what - leak is still there. Looks like I'll be tearing into the trans this winter.
