installed rider back rest BUT.........
Old 09-10-2007 | 09:35 AM
HDDOC's Avatar
HDDOC
Default RE: installed rider back rest BUT.........
This one. Doc
[IMG]local://upfiles/40283/54F03994673449379D94FA3AAE02B4DE.jpg[/IMG]
Old 09-10-2007 | 09:40 AM
Jim Dawson's Avatar
Jim Dawson
I installed one and finally got it where it is comfortable by moving it to the most rearward position. My problem is that I can change my exhaust system faster than I can get that damn backrest on and off.[:@]
What is the secret?
Old 09-10-2007 | 11:04 AM
steelhead's Avatar
steelhead
I have the same problem on the adjustable. I'm still trying to decide if I need to put some heat to it and bend it back or put it up for sale.
Old 09-10-2007 | 10:57 PM
baltimorebook's Avatar
baltimorebook
Well so far i've installed a 3/4" thick spacer at the front mount.
Next i'm going to heat it and bend it back a little while also cutting some foam out
If that still isnt enough i'll heat and bend the seat posts w/ the springs
then I will have to move the ladies tourpak back 2.5 inches
and if it still doesnt work -- new bars
Hell who wouldve thought this 200 back rest would end up costing me 8 hours of labor, a 200 set of bars, a 130 dollar tourpak relocation kit, then new of course i would need levers/cables........................................ and $1000 later, my backrest works
Old 09-10-2007 | 11:19 PM
voodoodrug's Avatar
voodoodrug
remember that story about the bean? under the mattress? it takes some gettin use to support back there but after a while would not ride a bike w/out imo
Old 09-10-2007 | 11:31 PM
tgaetto's Avatar
tgaetto
ORIGINAL: mllkn6
You have to re-bend the bracket on the backrest, open up the angle so the backrest is straight up with the bike. I have an old big vice that belonged to my grandfather without it I would have hada really tough time, but a few twist of the handlean it was perfect. Most try to heat it to bend it, it does not matter how it gets bent but it need to be bent just a little, a little goes a long way on this item. This is better than trying to shim the other part on the fender. Good luck.
Weird I did the same exact thing compliments of my Grandfather!
Then packed up for a ride to the gap strapped on the T bagg and forgot the back rest (Bagg was between me and the passenger rest very compfy for the ride down). Rode the whole trip with out it and realy wished I did not forget!!
Old 09-11-2007 | 07:00 PM
kurtlange's Avatar
kurtlange
ORIGINAL: mllkn6
You have to re-bend ...., open up ........tough time.....a few twist..... heat it......bend it,......get bent ......needs to be bent ....shim .....Good luck.
or just buy the mustang backrest.... http://www.mustangseats.com/roadglide/roadglide.shtml
Old 09-11-2007 | 07:48 PM
stro1965's Avatar
stro1965
I had to put some serious heat on mine to get those rods to bend...those things are tough! Some of you guys bending them without heat must be freakin Hercules! You can see in my sig pic the angle I ended up with. Just right for me.
Old 09-11-2007 | 08:43 PM
HarlyFan's Avatar
HarlyFan
Does spending the extra 100 for the fully adjustable backrest with the lever that you pull to make the adjustments have the same problem?????
Old 09-11-2007 | 09:35 PM
tgaetto's Avatar
tgaetto
ORIGINAL: stro1965
B.F.H!
Quick Reply: installed rider back rest BUT.........
