Spoiler Installed...Now Where the HE** Do Wires Plug In?
Old 09-09-2007, 10:22 AM
Stash's Avatar
Stash
Stash is offline
Default Spoiler Installed...Now Where the HE** Do Wires Plug In?
I've got the Tour-Pak spoiler installed, wires are run under the seat. Harley supplies a half Deutsch connector section and explains where to plug the three wire in.
THEN...directions say to "remove plug from the accessory connecter located under seat (connector number [4A] in wiring diagram in service manual). Connect wire from spoiler. Turn on Ignition switch and test spoiler light operation with taillight and brake light.
I have no idea where to plug this into. Also, I have no accessory plug under seat as shown in owners manual. WTF?? I do have a cig lighter in fairing that manual doesn't show
Anybody have a clue to where to hook this up?
Thanks!
Old 09-09-2007, 10:26 AM
UltraDuke's Avatar
UltraDuke
UltraDuke is offline
Default RE: Spoiler Installed...Now Where the HE** Do Wires Plug In?
I believe they are referring to the spare aux wiring connector near your battery. should be laying in there.
Old 09-09-2007, 10:48 AM
Biggzed's Avatar
Biggzed
Biggzed is offline
Should be on the primary side of your seat. I'm assuming this is the same connector that I plugged my SG rear facia light into. It might be tucked slightly under your rear frame horn cover.
Old 09-09-2007, 10:49 AM
jbleim's Avatar
jbleim
jbleim is offline
The instructions are correct. I just put mine on a couple weeks ago. The accessory plug they refer to is under the seat near the battery. Look in the gap in the frame between the battery and the gas tank an you'll find it. Mine was cable tied to another set of wires. I clipped the cable tie and was able to get the accessory plug to run along the left side of the bike frame under the seat. This way, all I need to do is lift the padding of the seat slightly and I can easily unplug the connector and pop off my tour pak in a few seconds.
Good Luck!
J.B.
Old 09-09-2007, 11:29 AM
Stash's Avatar
Stash
Stash is offline
I couldn't find the plug because it was buried under the battery. Took battery out and found that something else was already plugged into it. Since I have the battery out, I can't determine exactly what is plugged in. But, I'm guessing since I had the dealer add the parade fan to the bike before I took delivery, it' probably whats plugged in. Need to get a Y connecter to enable me to plug two items into the accessory plug.
Thanks especially for your help SOOS.
Old 09-09-2007, 11:33 AM
UltraDuke's Avatar
UltraDuke
Thats what we are here for. Good luck with the rest of the install.
Old 09-09-2007, 11:40 AM
fxesuperglide77's Avatar
fxesuperglide77
fxesuperglide77 is offline
Got a pick of theTour-Pak spoiler??
dagnabit9's Avatar
dagnabit9
dagnabit9 is offline
Do each of the spoiler (tourpak and each bag) lights have a running light and brake light in them? I'd like to get more brake light area on the back of the bike and that seems to be a good way to do it, if so... Oh, yes, pics would be very nice too..
Old 09-09-2007, 11:41 AM
fxesuperglide77
Does It fit on with the tour rack installed?
Old 09-09-2007, 12:15 PM
TexasRedneck's Avatar
TexasRedneck
TexasRedneck is offline
Yes, it'll fit even w/the large TP rack if ya install 'em properly....
[IMG]local://upfiles/19857/0D191D6581BF46C8BE1BC098CA92B2A2.jpg[/IMG]
Quick Reply: Spoiler Installed...Now Where the HE** Do Wires Plug In?
