Stepped on dealers toes?
Old 09-08-2007, 08:31 AM
BGHV65's Avatar
BGHV65
BGHV65 is offline
Default RE: Stepped on dealers toes?
Dude, it's time to test the lemon law in your state. If you can afford an attorney, get one and have him contact both the dealer where the bike is and the MoCo. 3 months for the same issues and all the different things done to it? That's excessive so I think it's time they stepped up and took care of you, maybe giving you another bike or something.
I really don't understand why we put up with this BS when if it was a car or TV, we would have already screamed to high heaven.
If we the consumers start putting some hellacious pressure on these shady dealers AS WELL AS HD for selling a defective product (if the bike we buy has issues that can't be fixed), in time we will weed out the bad ones.
To put your bike in the shop and have it sit for weeks on end untouched (???) I think they're ignoring the problem and hope you'll just get aggravated and come get it so they don't have to deal with it. I would be incensed...........
Old 09-08-2007, 09:21 AM
dgriffith's Avatar
dgriffith
dgriffith is offline
BGHV65, Yes I can afford an attorney, I paid cash for the bike. I,ve reached a point now that I need a phone number of a very good attorney. I don,t want to use a local that can be bought off. any suggestions out there??? Dan
Old 09-08-2007, 09:49 AM
DelawareDon's Avatar
DelawareDon
DelawareDon is offline
ORIGINAL: BGHV65
Some state's lemon laws do not apply to bikes. In Delaware for example, the lemon law is alive and well for automobiles, but does not apply to motorcycles.
Old 09-08-2007, 09:55 AM
06UltraBig95's Avatar
06UltraBig95
06UltraBig95 is offline
Not sure if I should mention or not, I had similar problems on both my 06 Ultras, it was the injectors. I still had the 8 degree.
Stealer swapped out both sets of injectors to 25 degree under warrenty, It did take a bit of convincing on how the bike was running and after the third different tech took out the bike they did agree something wasn't right.
Just my 2 cents
Old 09-08-2007, 02:02 PM
folkxrock's Avatar
folkxrock
folkxrock is offline
Give these guysa call. I am not sure if they handle bikes or your state, but they put Ford in their place on my behalf.
http://www.krohnandmoss.com/
Good Luck
Old 09-08-2007, 04:41 PM
drdiesel1's Avatar
drdiesel1
drdiesel1 is offline
Injector TSB for new style with additional nozzle holes and spray angle. This should be addressed first. Dealers are DumbAzzes. Make sure you have the new injectors installed. Look at them with a magnifying glass, get the part number andmatch it in the parts book.
You should also run a tank of fuel and add Chevron with Techron fuel injector cleaner to it.
Pull the air cleaner and clean the throttle plate and bore with some. This would be the correct starting point to fixing your problem.
It would be best if you could see what the T.P.S andI.A.C. valve readings areat idle hot. I.A.C counts should average 30 and TPS should be .4 to .8 volts. I would also like to know your start-up method. On a F/I bike you should turn the key to on and wait the the F/I lamp to go out. This resets the IAC counts and zero`s the system configuration. Idle and stalling conditions can be contributed to improper starting procedures too. I would also get a wrench on my battery bolts and make them tight. Not just a wiggle test. Use a wrench.
Voltage drops and low voltage will cause havoc with a F/I bike. Now get your bike back front the DumbAzz dealer and fix it yourself. I`ll help all I can onhere.[8D]
Old 09-08-2007, 04:45 PM
Roofuss96's Avatar
Roofuss96
Roofuss96 is offline
I think I would have gotten some legal advice/action by now.--Yup, time to call the eagle on this one ! [sm=smiley7.gif]
Old 09-09-2007, 04:31 AM
PapaTravis's Avatar
PapaTravis
PapaTravis is offline
I would ask when they would get to it, and demand a little compensation. Say a rental will do until you can get to it. I would not leave until I was satisfied. And, if all else failed, I would send my wife in... LOL. She can get whatever needs to be done, done. Some call her a b!tch, I call her, honey. LOL
Old 09-09-2007, 05:52 AM
NCCopBikeRider's Avatar
NCCopBikeRider
NCCopBikeRider is offline
Contact your State's Attorney General's Office
They should do it for free
Ride Em Carry Em
Old 09-09-2007, 07:42 PM
choochoo's Avatar
choochoo
choochoo is offline
yep! There is it is called a lemon law. all states have one
ORIGINAL: 1FLTRI4ME
I think I would have gotten some legal advice/action by now.There must be a law regarding a company that will not fix or cant fix a vehicle that has a warranty.
Quick Reply: Stepped on dealers toes?
