Touring Bike Center stand
I just won a bid for a usedHDtouring bike chrome center stand for my '05 EGC. The seller doesn't seem to know how it's mounted to the bike. It appears that two lugs mounton theengine guard bolts (with spacers) and two lugs are bolted under the voltage regulator. Is this correct?
Gregm
Gregm
RE: Touring Bike Center stand
I bought the Rivco centerstand.Their adjustable versionworks fine on my 06 FLHT/I with Harley Low Profile shocks. Very easy to install, two bolts in the hour glass part on the lower frame. It is a handful to get it on the centerstand after riding all day, but worth it while cleaning or servicing the bike.
capt42a
capt42a
You are correctfor the front mount. If you did not get the nuts & bolts you will need to find longer bolts. Hopefully he gave you the spacers for the crash bar/engine guard. The studs under the voltage regulator you will have to drive out(they are pressed in).
Arvid
Arvid
terrylinda08SG
Touring Parts
11
08-02-2013 09:33 AM
