Wet Spot
Wet Spot
Ok it's not on the sheets. It's on the ground right under the primary case drain. Never drips except when I ride it on a hot day for some distance. I did replace the primary gasket when I put in a automatic chain tensioner. Could it be the jackshaft seal and how do I tell. It looks like 10W-40 oilI put in the primary so I am sure it is not the transmission. Any help would be appreciated.
matt
matt
RE: Wet Spot
Is it coming from the backside of the inner primary cover?
Or
Is it coming from the drain itself?
After you replaced the primary cover gasket.....did you replace the inspection covers as well? If you re-used those, they have a habit of seaping while you ride. The fluid ends up at the location you are describing.
Or
RE: Wet Spot
ORIGINAL: 52edub
matt
matt
Terminator69
10-07-2011 12:18 PM
