warped rotor after 6,000 miles ?
Old 09-04-2007 | 08:01 PM
tomracer69's Avatar
tomracer69
Default warped rotor after 6,000 miles ?
07 rkc seems the rear rotor is warped.. how does a rotor just go out of true? bike is running good now out of now where it sounds like the rotor is out . when its hot very noticable. would this be under warranty? tommy nyc
Old 09-04-2007 | 08:47 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default RE: warped rotor after 6,000 miles ?
ORIGINAL: tomracer69
If the rotors are indeed warped it would be covered under warranty.
Is it making anintermittant rubbing sound at low speeds? Elaborate a bit on what it's doing.
Old 09-04-2007 | 08:59 PM
G$'s Avatar
G$
From: LexVegas, KY...home of fast wimmen & beautiful horses
.....that's highly unusual at 6K. Might be more of a stickin caliper or worn pad
Old 09-04-2007 | 09:01 PM
tomracer69's Avatar
tomracer69
more info ...yes the rubbing is intermittant. very noticeable when hot....its not so bad, but hate bring to dealer but i belive its getting louder. how does a rotor go out of spec after 6,000 miles ....thanks tommy
Old 09-04-2007 | 09:04 PM
tomracer69's Avatar
tomracer69
when i roll the bike cold no noise so i was not thinking of a calipr issue but ....i geuess a trip to dealer is in order....i hope to heck they do not have that infamous red road glide!!!!!!!!!
Old 09-04-2007 | 11:08 PM
MNPGRider's Avatar
MNPGRider
I have a front rotor out of true by .004 . Warranty will not cover it until .008 . It is just enough off that it grabs right at the point of stopping, causing an imbalance. I have bitched and complained, but they will not replace (and I bought the 7 year warranty!) I told the service manager I was going to take a hammer to it to make sure it was more than .008 out of true.
Rotors usually warp during heavy usuage in the rain, whether it be car or cycle. Hot braking, cold water, warped rotor.
Old 09-04-2007 | 11:17 PM
parakiller's Avatar
parakiller
interesting...I have felt the pulsing and hear the rubbing in the front as well as the rear of my bike...07 RKC also...I will have them check it when they put on my tire and my IDS.
Old 09-05-2007 | 04:33 AM
IndyRider's Avatar
IndyRider
I had the same problem with my 06 RK with 8000 miles. Front brakes had a lot of palsating in them to the point that I rarely used them. Finally changed the rotors out with H-D floaters and Lyndell Z pads. Made all the difference in the world. Front brakes are great now.
Old 09-05-2007 | 06:23 AM
Point Man's Avatar
Point Man
One of my front rotors is warped too. Grabs and pulls at low speed; be careful at red lights/stop signs. Mechanic says the rotors usually warp in the same spot, near one of the groove cuts, where it's weaker. I use the rear brake more for the low speed stop. Will replace soon with an aftermarket rotor, most likely...
Old 09-05-2007 | 06:38 AM
1flhtk4me's Avatar
1flhtk4me
Easy to check with a dial indicator.
Quick Reply: warped rotor after 6,000 miles ?
