Wheel bearing question...
Old 09-03-2007 | 10:46 AM
Dalej's Avatar
Dalej
Default Wheel bearing question...
I have my 04 broke down to put the 3rd rear tire on and was wondering when to replace or what to do about the wheel bearings. Not sure on this part since my owners manual doesn't say a thing about it. Bike has 24,500 miles on it.
Old 09-03-2007 | 10:50 AM
Biggzed's Avatar
Biggzed
Default RE: Wheel bearing question...
They are a sealed wheel bearing. Should be good for 100,000 miles. Put a new tire on and ride.
Old 09-03-2007 | 10:58 AM
Dalej's Avatar
Dalej
Thanks, I did a search and found out they were sealed since 00, but didn't know if they should be replaced at certain intervals.
Just hate to have problems on the road.
Old 09-03-2007 | 11:33 AM
FastHarley's Avatar
FastHarley
Former Sponsor
ORIGINAL: Dalej
The 2001 & below to 1999 are sealed but 3/4" axle, 2002 to 2007 are 1" & the new ones are 25mm.
Old 09-04-2007 | 07:35 PM
tallboy56's Avatar
tallboy56
Take the bearing to a local industrial bearing distributor and see if they can match it. If it's metric, that's better since most bearings are metric. The 25mm bore is one of the most common sizes used in electric motors, gearboxes, etc. Without seeing the bearing I would guess it's either a 6205-2RS or 6305-2RS...both are 25 mm bore but the latter is heavier cross section meaning it has higher capacity. Obviously, you have to put the size back in there that came out but I would hope that HD put in the heavier size. You can't say that they are good for 100,000 miles...damage can occur when they are improperly removed, installed, contaminated, etc.
Donnylee
12-20-2017 11:55 AM
blackflame
07-11-2015 10:28 AM
bbflhrs
09-17-2010 09:29 PM
07JakeelwoodHD
08-09-2010 10:17 AM
chevelless502
03-17-2005 01:40 AM
Quick Reply: Wheel bearing question...
