Check engine light when full throttle
One person that's an expert on this is @Ed Ramberger . Hell get a notice for me tagging him.. He should have some info..
At initial key on, if the CEL comes on for 4 seconds and goes off and stays off, it has no current codes - but may have historic codes
If it comes on for 4 seconds, goes off for 4, then on for eight, then off, there is a functional error - codes 52-55 and 56. It may have historic codes.
If it comes on for 4, off for 4, then comes on and stays on it had a current code/fault. It may have historic codes.
The following 2 users liked this post by Ed Ramberger:
hattitude (Today),
Max Headflow (Today)
It does being up a thought tho.. I don't know if MM senses coil primary voltages injector drive voltages like the Delphi but maybe the coil promay or one of the injectors has increased resistance and the ECU senses the wrong voltage at higher Rs?
I'd start by checking wires / connectors on those locations.. Check resistance on the coils and injectors also. Tug on the wire going into the coil and injector connectors. If stretchy, they are likely broken inside.
The 02 has a Delphi system that uses the plug for ion sensing. The MM 2000 does not..
To be sure and start OP may want to verify charging system if doesn not have a tuner or scanalyzer to read codes.
So if it were a loose connection or even higher resistance where it might show up with RPMs, it would correct itself as the RPMs dropped?
Also if the bike has a powercommander on it, remove it and see if problem resolves - unless the build is so radical it would be unsafe for the engine to run it
hattitude (Today)
For this model, Historic trouble codes are not seen using check engine light diagnostics, they are only read with a scanalyzer.
Well, Ed
That manual says you can use the check engine light for diagnostics.. It seems to say that codes are stored and can be dumpedso you should get historic too..
Not correct..
If you have a historic code, the light don't stay on when ignition is turned on like you said, it goes out after 8 seconds.. IIRC it's pretty much the same as early delphi.
Not correct..
As I said in post 12, per the manual historic codes are only obtained through the scanalizer only. Last paragraph states this below. Not sure exactly the confusion but will gladly try to figure it out. Here is my take on it. A TP has a code. It is not resolved, the ECM sees it and keeps it as current which is readable through the scanalyzer or light. If it resolves and the ECM sees a start cycle, it goes historic and can only be read through the scanalyzer.
