Almost stage 1 with PCIII and pipes
I had purchased a used set of Python touring slip-ons from a friend and tried them on my bike. Got lots of decel popping. Read many posts here about needing or not needing to add a fuel management system when just using pipes. I checked with several dealers and independant repair shops and got as many different answers from them as there are opinions here. Sme said the bike will automatically adjust the fuel, some said get a sert, some said a fuel pack, some a PCIII, some a hd download...and on and on.
To be safe, I removed the pipes. I was able to purchase a used PCIII from a member here. I installed the power commander download for a completely stock 06 touring into the PCIII and reinstalled the Python slip-ons.
No decell popping at all. Did not "feel" any difference in performance. Did notice the extra cranking to start, but no extra cranking if you hit the start right after pushing the kill switch to "on".
Now to decide should I spend the $125 for a K&N RK-3909 air filter kit?
Just wanted to let others know my results and gather opinions on the air filter.....Thanks.
RE: Almost stage 1 with PCIII and pipes
I have the PCIII, SE Air Cleaner, Wild Pig pipes on V&H Dresser Duels on my 2006 Street Glide. I had the Stage 1 HD download with this set up before installing the PCIII and had decel popping also. The PCIII took care of that and with the PCIII is where I noticed the biggest change in "power". I did all of the changed one step at a time and noticed very little change until adding the PCIII.
Just my experience.
Ride Safe,
Mike
Just my experience.
Ride Safe,
Mike
ORIGINAL: 2106HD
Some said the bike will automatically adjust the fuel, some said get a sert, some said a fuel pack, some a PCIII, some a hd download...and on and on.
To be safe, I removed the pipes. I was able to purchase a used PCIII from a member here. I installed the power commander download for a completely stock 06 touring into the PCIII and reinstalled the Python slip-ons. No decell popping at all. Did not "feel" any difference in performance.
ORIGINAL: iclick
Unless there's something I'm missing, the '06 Delphi open-loop EFI won't auto tune at all. There is no input from which it can determine what to do. In the case of the '07's, the narrow-band closed-loop EFI should compensate for changes while in closed-loop mode, which is mostly in the idle and cruise modes. At full-throttle there will be no adjustment.
I'll cover this later in my thread, but in respect to our previous "conversations", DO NOT put the 02s in line with the PC-III if you don't want trouble down the line with your PC mapping.
Turn ignition on, then start immediately. Don't wait for the "check engine" light to go off.
ORIGINAL: SoCal_Pappy
Air Filter Kit - Highly recommend Ness Big Sucker!!!
Todd Vikan
08-05-2006 04:59 PM
