hd detachable passenger backrest to far foward?
Old 09-02-2007 | 04:44 PM
sportyrider1's Avatar
sportyrider1
Default hd detachable passenger backrest to far foward?
My hd detachable backrest seems to be to far foward with my mustang 2 piece touring seat. I seem to be losing about 2 inches of seat and when I add my nelson rigg pack my wife feels cramped is there any backrest assmbly that is futher back?or any thoughts.
Old 09-02-2007 | 04:48 PM
0204665J's Avatar
0204665J
Default RE: hd detachable backrest to far foward?
I do know my Mustang seat with its' back rest still push me more forward more than my stock. Using washers on the backrest help, but I ended up having the stock seat re-cushioned and set back an inch and I am happier about it.
Old 09-02-2007 | 05:08 PM
SoCal_Pappy's Avatar
SoCal_Pappy
Have you tried to adjust your HD Backrest (the base mount under the seat attached to the rear fender)... I had to shim mine back & up a bit using my Sundowner seat... But that's only going to take more room away from you Pass seating area...
Old 09-02-2007 | 05:40 PM
SG 1's Avatar
SG 1
I took your post to mean PASSENGER detachable backrest. If I'm right, I have the same problem and would like a way to move it back about an inch. I think that is as far as you can go before you get into the saddle bag brackets.
Old 09-02-2007 | 06:33 PM
fatboyemt's Avatar
fatboyemt
If you're talking about the rider backrest then checkout https://www.hdforums.com/m_1989483/m...tm.htm#1989483
Old 09-02-2007 | 07:10 PM
sportyrider1
ORIGINAL: SG 1
Yes, sorry about that I did mean the passenger backrest
Old 09-02-2007 | 07:29 PM
SoCal_Pappy
There ya go... Now we're on the right track...
Your Mustang seat moved you (Rider) back about 1".. There is no adjustment that I know of for the Passanger Detachable Backrest???
Old 09-02-2007 | 07:44 PM
Bighorse's Avatar
Bighorse
Same problem on my EG but I have learned to adjust to it. I bought another seat but it wasn't any help.
Old 09-02-2007 | 09:04 PM
kt's Avatar
kt
Take the black metal strap back boltloose fromthe detachable bracket & move it down alittle & drill a new hole for it in the mounting bracket, it will move the backrest back about an inch & change the angle also, gives quite abit more room.
Old 09-02-2007 | 09:16 PM
Badbagger's Avatar
Badbagger
Default RE: hd detachable passenger backrest to far foward?
Check this info out and it may give you some ideas on how to correct it:
http://www.moccsplace.com/images/harley/fcrack/rack.htm
Quick Reply: hd detachable passenger backrest to far foward?
