Battery/starter/comp?
Which PowerVision tuner do your have?
I have a full service PowerVision tuner and have never seen a file say "read only".
Apparently you do not have the option of turning the compression release on and off....
Luckily, your active compression release is turned on in that tune...
I have the original PV. Bear in mind that is just the app and the tuner is not connected to the laptop. I just wanted to search the info to see where it was. I can check the box I believe for the compression release. I just wasn’t sure if I should. I’m not experienced enough to make that call however I’m thinking now that what the heck , I can always reload that tune again right.
OK, you're totally out of my area of understanding....
I know nothing about "apps", I have none, zero on my phone, and I only use the tuner attached to the bike for flashing tunes, data logging, auto tuning, and quick tunes. Any other tables I touch are done in WinPv on my laptop....
For that reason, I'll have to bow out at this point...
I have no idea how, or where, you are seeing that screen if it's not on a laptop, so I can't offer any intelligent advice.
Most other people probably understand what you are seeing, where, and what you want to do.... so I will leave it to them to offer valid advice..
Good luck with your tune..
hattitude (Yesterday)
Oh... my bad, I thought you were doing this on your phone... something I just don't do with anything, nor have I any experience with.
Apparently the "read only" is because there is no tuner attached. Funny, I never opened a tune in WinPV without a tuner attached before. I learned something new...
IMHO, if that is the tune you are using on your bike, it shows the Auto Compression Release is turned "on". So unless your wires/connectors to the compression release(s), or the compression release(s) themselves have an issue, your starting issue is from some other source..
With all you have tried and done it sure points to the tune.
When you started this mine and others first thought was the battery.
Bad battery's don't always test Bad but having it done at 3 places and all saying it's good Damn.OK LOL
Didn't reread but didn't you mention you tried a known good battery ??
Dynojet as a rule has good customer service.
Sure hope they can help ya
Good Luck WP
Good Luck WP
Good Luck WP
Good Luck WP
Thanks. No I didn’t try a know good battery. Didn’t want to spend a couple hundred if I didn’t have to. Hopefully the Dynojet rep might be able to offer up some advise in what I might be doing wrong.
WP50 (Today)
TexasBikeBoy
EVO
17
01-23-2013 06:15 PM
1984 fxrt, won't start. i replaced the battery and the solenoid. it doesn't want to turn over. or i?
huey54moore
08-12-2007 10:44 AM
